Posted on Friday, February 8, 2013 at 9:01 AM
I've not had much luck with the wheels and tyres on either of my 545i Tourings. The first one was always a little vibratory on the motorway until the garage spotted that two of the wheels were cracked, so they never balanced properly and gradually lost pressure. These cars are very sensitive to the pressure being wrong which doesn't help; not only does it upset the suspension but it seems that it messes up the wheel speed sensors and steering angle sensor and confuses the ESP. By the time I sold the last one I'd had a full set of tyres, a set of new wheels (used the best two to replace the cracked rims, threw away the cracked ones and sold the remaining two) and it drove smoothly. So I was quite pleased that the second 545 drove smoothly at first (on a combo of two Dunlop run-flats, a Goodyear run-flat and a Falken normal tyre; I didn't mess with this until they wore out because it felt fine). Ever since the complete new set of tyres was fitted last September, two have gradually been losing pressure. So gradual I couldn't get the bead to produce any bubbles when covered in Fairy Liquid, but enough to need topping up 4-5psi every week. Since the car's so sensitive to pressure I didn't even trigger the TPMS warning before knowing I needed to top up so this wasn't too annoying. But it did need fixing so I bought a set of decent wheels (which happened to come with one pair of good Dunlop run-flats on, pleasing) and on Monday I went to a tyre place to get the wheels swapped over for the decent ones with less corroded edges. I noticed that one of the other tyres was low on pressure - irritating, obviously a puncture. So I had that fixed at the same time. During this week I've noticed the handling and stability was a bit wayward, which I thought was because the tracking was out. Then this morning the steering was quite heavy turning left, I thought a wheel bearing was failing due to the grumbling, and after a mile or so the TPMS warning came on; I guessed the previously punctured tyre was not repaired properly. And when I stopped to top it up, the pressure was really quite low (surprised the TPMS didn't trigger sooner, to be honest). Felt fine back at normal pressure but I've got yet another puncture to fix. Why do I have such rotten luck chasing tyre problems on E61s?
Posted on Friday, February 8, 2013 at 9:04 AM
Fit inner tubes.
Posted on Friday, February 8, 2013 at 9:16 AM
I overhead the tyre place (who failed to fix the puncture) telling someone on the phone they couldn't fit inner tubes now. Sounded like they would like to do so  TBH I'd have been better off doing a string repair myself.
Posted on Friday, February 8, 2013 at 10:45 AM
scotta
Make sure they use a bit of bead sealant when they refit the tyre.
Diesel Accord 150.47921 BHP
Posted on Friday, February 8, 2013 at 3:53 PM
SimonB
Shouldve paid more than a tenner to get them fitted proper  One of the reasons I refuse to put expensive tyres on mine is the common ruining of the rears due to the standard camber. In other news the tax is now 270 a year. Daylight robbery
Posted on Friday, February 8, 2013 at 4:16 PM
Mark BT52
SimonB said... One of the reasons I refuse to put expensive tyres on mine is the common ruining of the rears due to the standard camber.
Our 750 wore the inner edges at a stupid rate and barely touched the outer at all. Seems to be a BMW trait, I remember asking my dad in the 70s/80s why the rear wheels of the BMW in front of were leaning in so much at the top.
Posted on Friday, February 8, 2013 at 4:53 PM
SimonB said... Shouldve paid more than a tenner to get them fitted proper  One of the reasons I refuse to put expensive tyres on mine is the common ruining of the rears due to the standard camber. In other news the tax is now 270 a year. Daylight robbery
This set was bought from and fitted by Event Tyres, I'll have you know. I didn't order cheap ones from the internet then pay through the nose for fitting like you  As I mentioned previously, the rear tyres are wearing fine; not noticeably more on the inner side than the outer. Just as they did on all of my other BMWs. KDS alignment for the win.
Updated February 8, 2013 at 4:54 PM
Posted on Friday, February 8, 2013 at 6:56 PM
Your car shouldn't be wearing the tyres out unevenly. Jobbo - stop being such a tight arse.
Posted on Friday, February 8, 2013 at 6:59 PM
Certain tyres in my set of Avus 1s used to lose about 4-5psi a week. It was mainly because of corrosion where the tyre bead sits and a bit of corrosion around the valves. This was solved by having all four wheels powedercoated and new tyres fitted (tyres needed replacing anyway) The tyres haven't lost any pressure since November. Same with my 968 wheels - since having them powdercoated, they barely lose tyre pressure either.
Posted on Friday, February 8, 2013 at 11:29 PM
Orange Cola
Mito Man said... Your car shouldn't be wearing the tyres out unevenly. Jobbo - stop being such a tight arse.
Buy a real car. HTH. Jobbo, I had my BMW geo set up after I bought it and ditched the run flats. I was chatting to the bloke who does the setup and he reckoned most BMW's carry one person 95% of the time and even when there are more occupants it's rarely with people and luggage in the boot so setting the Geo to the most common usage would get the tyres to last. My rears have worn much more evenly since but they're still not perfect. BMW's fault for fitting SLA on the rear, mcphersons on the front and making the distance between the two a bit big
Posted on Saturday, February 9, 2013 at 6:04 AM
Sorry, how does moaning about punctures turn into being a tight arse and wearing my tyres out quickly? It's Broccers who is the tight arse who has wear problems
Posted on Saturday, February 9, 2013 at 9:00 AM
Jobbo said... It's Broccers who is the tight arse who has wear problems
Posted on Saturday, February 9, 2013 at 9:23 AM
So Beemers have tyre problems and indicator problems and expensive gearbox problems. That will be the teutonic build quality then?
Posted on Saturday, February 9, 2013 at 9:40 AM
Should chop the back end apart and fix the geometry problems. I'll get my big saw. Dave!
Posted on Saturday, February 9, 2013 at 9:57 AM
I don't think there's anything innately wrong with E60s when it comes to wheels, tyres and suspension; I've just been unlucky with punctures and pot holes. Of course, compared to a Saab it actually handles well so it's possible to feel when the tyre pressure is low
Posted on Saturday, February 9, 2013 at 11:54 AM
...And the problem is: a crack in the alloy. FFS. Good job I've bought a new set, really.
Posted on Sunday, February 10, 2013 at 1:21 PM
Sideways
Mark BT52 said... SimonB said... One of the reasons I refuse to put expensive tyres on mine is the common ruining of the rears due to the standard camber.
Defintely a BMW trait, but not exclusively limited to them it would seem. I had the Abarth's geo checked a couple of weeks ago as the inner edges of the front tyres are wearing. My Tuna confirmed that all was near enough.at factory settings and thus this wear is normal. He added that it's quite common for BMWs and all manner of other cars to display the same trait due to how their geo has been designed.
Posted on Sunday, February 10, 2013 at 6:30 PM
SimonB
Im a proper cheapskate with this car that is very true.
