Forums > General > How to convert JPG, PNG files to PDF format effectively?
HOW TO CONVERT JPG, PNG FILES TO PDF FORMAT EFFECTIVELY?
The most effective way to convert image documents to PDF format is using Image to PDF Conversion program. With the kind of conversion program, it saves time and effort. Image to PDF Converter is such a wonderful and professional image to pdf conversion tool.
Image to PDF Converter supports popular scanned image to PDF format like JPEG, GIF, PNG, BMP, TIFF,etc. When converting image to text PDF, the Images to PDF Converter software can adjust the image display position on the page, or image quality (low, medium, maximum).
For protect created PDF file from modification or copy, this advanced Image to PDF Converter designs password encrypting function. Up to 128 bit password strengthens file's security.
Converting image to PDF is only one function supported by :)OX Image to PDF Converter, it is also allowed to convert between different image formats like JPEG to GIF, JPEG to PNG, etc.
The solution on how to convert JPEG to PDF as following:
1. Download and install the Image to PDF Converter.
2. Add some JPEG files you want to convert into the software.
3. Set the files as you like.
4. Convert import files into PDF format.
Hello,
To protect image files from many corruption threats, you can save it in a secured file format such as PDF. Kernel for Image to PDF is a proficient tool that integrates different image files in a single PDF file. It saves images in low, medium or best quality in the Output file. This software supports different file formats of image such as .JPEG, .JPG, .PNG and .ICO. It also provide an option to save converted images in user specific dimension.
You can get more Information from here http://www.imagetopdfconversion.com/
Thanks dude!
thats a really good method of doing it
until now i was bound to online converters
but they are useless in my opinion when it comes to mass conversions,
so thanks again
regards
peter
Updated May 2, 2013 at 1:01 PM
DOWNLOAD PHOTOSCAPE
ITS FREE AND 100 TIMES BETTER THAN THE CRAP THEY ARE TRYING TO SELL
PHOTOSCAPE
PHOTOSCAPE
PHOTOSCAPE
