Forums > General > FAO of Mik
FAO OF MIK
You famously rigged up a cheesegrater or dishwasher tray or something to widen the throttle pedal on your '''''8, didn't you? I'm guessing you've found a more permanent solution now - what is it? Just a.n.other pedal extension kit?
My JFDI New Year's Resolution means I'm finally tackling the 1m gap between the brake and throttle pedal on the ''''''''''5.
All was revealed in this thread here my good friend. :D
I wanted to fit a "std pedal extension" but when i went looking, they seemed far harder to find than I had anticipated. :?
It made such a difference (to me) in terms of the level of interaction when pressing on. H&T FTMFW. 8)
Thanks Mik - it all becomes clear now :lol:
They are surprisingly hard to find, I must admit - I thought it would simple enough to find a product to sort this out but like you, I think I'm going to have to resort to drilling and bodg..........erm, engineering :lol:
Hi jl.
BMW M products are the result of many years of research and development by the worlds finest engineers. The pedals are placed perfectly as dictated by an unparalleled level of driver / vehicle interaction and should need no alterations.
I suggest a leg or foot transplant instead.
Hth.
Hello inteRgrale_evo,
Thank you for clarifying this, and please accept my full apologies for DIW.
All the best,
jl
If my right foot was an inch wider it would all be gravy, but it ain't.
But feet are different out there Harry. :idea:
Please make the pedal extension out of an ///M badge.
integrale_evo said...
Hi jl.
Hth.
Even the BMW Mini has the pedals positioned perfectly for H&T (the first gen, at least)
This is absolutely true, actually - my mate's Cooper S had perfectly-spaced pedals, H&Ting was natural from the first downshift.
I assume the e39 has the usual floor hinged accelerator?
If so just take your pick of aftermarket BMW pedal covers off eBay or similar, fit it over your pedal and offset the desired distance from the brake pedal, drill and bolt.
You'll probably only be able to use two mounting points instead of the four, but it'll still be plenty secure enough for an accelerator pedal!
Pretty sure the standar pedal is plastic anyway so should be nice and easy to drill.
Hi JL,
I heard 911 Turbot pedals are perfectly spaced for H&T.
HTH.
Best regards,
Duncs500
Touche Duncs :lol: - still looking every day :D
PS thanks Harry
Updated January 17, 2013 at 10:23 AM
PS thanks Harry
:) I'm going to file this under your very own mantra that if you want better performance from a car, get a better performance car, rather than spending time and money tuning what you've got.
Even down to the pedal spacing? :lol:
Yeah, practice what you preach! I'm sure the last time you rolled that one out all Beany wanted to do was polish his Puma.;)
duncs500 said...
duncs500 said...
's MAF :lol:
