Forums > General > How do sending a fax from my computer?
HOW DO SENDING A FAX FROM MY COMPUTER?
Any suggestions?
My agency require a fax of my timesheet but appear to have not noticed that I don't live in the 1980's. (apparently I can't telex it either)
Thanks, geeks.
All retch and no vomit
Can you not scan and email?
Is efax still going?
efax.com
Nope, has to be fax. No email address provided.
efax.com
£7.50 to send one fax a week! :shock:
'kin ell!
If you don't have a multi-function printer which will fax then why not just do it from your client office?
Tim
Balance Bikes from STRIDER & Kiddimoto, HARO BMX Bikes to suit from age 4
Here
Here
Nice recommendation. :roll:
I looked at that a few years ago and eventually gave up - I could not find any way since my PC has been connected with an ADSL box, I could not find any appropriate software (like the ones existing for modems).
Only solution was to print and then go and fax from a Post office.:shock:
Efax works on Android or iPhones, install the app, take a photo of doc, push it through the app and it comes out of the FAX machine the other end. Simples :)
Don't most laptops have built in fax/modems.
Jimmy choos new computer
Steve
Jimmy Choo said...
Here
So I recommend one and that's apparently too expensive. Then I tell you to search for a free one because I've only ever used efax and I get the rolly eye treatment.
What's your fax number, I'll fax you a moon on a shitty stick.
carlos said...
If Jimmy looked at the above he could recieve your shitty fax*
* assuming the choo's have a smartphone :D
carlos said...
carlos said...
I suggested efax 3 times. Frankly, he can go fax himself.
Updated January 5, 2013 at 9:36 PM
Well, after some research I've discovered efax. They also do a 30 day free trial. I shall try that.
I'm surprised that none of you have used it.:roll:
Oh, and Steveo, a friend of mine still has one of those!
Tell the company to get up to date with emails or they'll quickly loose a lot of business.
75% of the financials I deal with cant/wont except scanned and emailed doc's but will take a fax :roll: and I am talking about some of the biggest companies in the world.
I have to do 3 time sheets, and so far nobody has told me wether or not I'm DIW.
I should get paid sometime in the next week or two - that'll be the acid test.
