Forums > General > VW Passat 2.0Tdi Estate - initial thoughts
VW PASSAT 2.0TDI ESTATE - INITIAL THOUGHTS
Basically, this in Jet Black:
Initial Pro's
Usual Repmobile stuff - Reasonable levels of kit (Cruise, Sat Nav, IPod etc), mahoooosive space, 50/60 mpg expected. I also like the little down lights under the sills when you unlock.
Initial Con's
Radio is the worst piece of un-intuitive crap I've ever come across in a car - VW's older system was much better IMO - Good stuff like the fact the pre-sets can be set across band (for a single set of stations) is ruined by the fact that the selectors are just numbers with no indicator of the station. I've also decided I don't like Stop / Start anymore. Also, from certain angles and in certain lights, it looks like a hearse :lol:
This car was supposed to be a 2.0TFSi A4 Black Edition but for various reasons I won't go into here, we had to take this instead (A4 will now be next) so, while not what we wanted, if what you want is a car to lug loads for 100K per year, it would be brilliant
Updated January 4, 2013 at 9:58 AM
Dinny_G said...
...50/60 mpg expected.
Our older version (2006) will do 60mpg on the motorway without trying too hard. It's averaging just over 40mpg on the wife's commute that's a bit start-stop and probably doesn't get over 50mph at any point.
Impressive for such a big car.
I think my neighbour misunderstood when I said 'I can't wait for the next 911'
My brother has one of these. Bluemotion?
He easily gets mid 50's MPG, however he drives it.
This ^
Yeah probably - delivery mileage at the moment so I'm expecting the current 47mpg to increase especially as she'll be doing most of the driving in it.
Same engine as our Tiguan I assume, bit gruff sometimes but impressive pulling power and refined when crusing.
So, how do you end up buying a car you don't want, or is it a company car?
Yeah company car of sorts...
Does the stop/start really bother you?
I have a saloon Passat and find it quite un-intrusive.
It only activates when I'm stopped and in neutral, so at junctions or where I'm only going to be stopped a few seconds, I just leave it in gear with the clutch in.
I find it really irritating on my E91 and always deactivate it. If I'm at the lights I don't want to sit there with the clutch in all the time.
McSwede said...
So stick it in neutral and let the clutch up. Or is that too obvious? None of the start/stop systems I've used have bothered me once I got over my fear of it not starting, due to years of driving snotters :lol:
McSwede said...
There's no fear of it not starting I just don't like it hence why I deactivate it on each journey. Even the dealership say they can't permanently deactivate it.
The car's stalled twice which I'm blaming on the stop/start, rather than my inability to mix revs, torque and weight into forward momentum!! :lol:
