Posted on Saturday, December 29, 2012 at 10:42 AM
RingNut
I want to do a complete wrap on a van with custom picture.
I'm in Bucks, but can't find much anywhere.
Any ideas ? Has anyone tried to do this DIY ?
Congratulations, you came second.
Posted on Saturday, December 29, 2012 at 12:59 PM
lepetitoeuf
If you wanted to do it yourself, I could print it for you. We don't get involved in wrapping though. You could try someone like pyramid visuals for the full service.
Large format print & graphics
Posted on Saturday, December 29, 2012 at 6:35 PM
Focus69
Doing a full wrap by yourself must be a real PITA.
Posted on Saturday, December 29, 2012 at 7:27 PM
RingNut
lepetitoeuf said... If you wanted to do it yourself, I could print it for you. We don't get involved in wrapping though. You could try someone like pyramid visuals for the full service.
Are you in that trade ? I'm after (don't laugh) a woodland / forrest scene, maybe with little fluffy bunny rabbits, or somthing equally PITA, can't be that hard can it, especially on a flat sided van ?
Posted on Saturday, December 29, 2012 at 8:31 PM
focus69 said... Doing a full wrap by yourself must be a real PITA.
^^ What he said ^^ Probably alot of potential for royally fvcking it up.
Posted on Sunday, December 30, 2012 at 9:53 AM
Simon_667
doesnt Gwared do this kind of thing?
Do not act as if thou wert going to live ten thousand years. Death hangs over thee. While thou livest, while it is in thy power, be good.
Posted on Sunday, December 30, 2012 at 10:48 AM
No, Rev is correct. I do half wraps & pictures etc, but a full wrap is a PITA. Too much to go wrong, prep is crucial, the material must be the right kind matched to the right laminate to stay on & ends up being really expensive. Temp for fitting is crucial too as is pre & post heating of the material. Other than that, it's a piece of piss to fit, that's whay everyone DIY fits these
Many cowboys print & fit for cheap, but it'll be peeling & blowing the recesses in a few days, especially in this temp. Ask David Yu how much a proper decent wrap should cost.
Updated December 30, 2012 at 10:49 AM
Cheers, Gwaredd Steele Signs
Posted on Sunday, December 30, 2012 at 10:58 AM
RingNut
Gwaredd said... No, Rev is correct. I do half wraps & pictures etc, but a full wrap is a PITA. Too much to go wrong, prep is crucial, the material must be the right kind matched to the right laminate to stay on & ends up being really expensive. Temp for fitting is crucial too as is pre & post heating of the material. Other than that, it's a piece of piss to fit, that's whay everyone DIY fits these
OK, I'll come clean.....
I want to wrap just the two sides of a caravan,
Can you help ?
Posted on Sunday, December 30, 2012 at 11:17 AM
If it's a dead flat surface (like a sainsburys artic trailer), then yes. You won't even need to print onto a wrap material. The second you start putting it in recesses & trying to bend it round curves, then you get problems. I use a material called Metamark MD5 for my printing & it's a fab product, although it will be a pig to fit as the adhesive is very grabby. For DIY fitment on a flat side, you'd want to spec an air release vinyl. This has a special pattern on the glue side of the vinyl that lets you 'chase' all the air bubbles out when fitting. Again, not really for curves etc & is more expensive. Fitting will be like hanging wallpaper when lining the image up & you'll want a 5 - 15mm overlap on the material. Cleanliness of the surface is key to it lasting, especially the edges where it stops.
