Posted on Tuesday, December 18, 2012 at 9:44 AM
dudeluk
I'm looking to fit a hitch to the old family bus (Touran). Can anyone recommend a place in the UK that fits them for reasonable money. Or should I attempt to do it myself...?!
Thanks!
Updated December 18, 2012 at 9:45 AM
Posted on Tuesday, December 18, 2012 at 9:52 AM
Very easy to fit. All the mounting points for the tow bar will be on your car and if you buy a dedicated wiring loom it will plug into a socket already fitted to your car.
Posted on Tuesday, December 18, 2012 at 10:11 AM
Dr Carlos
Like John says it's a pretty easy fit, takes about 3 hours all in even when you have captive nuts that are heavily corroded on the threads. This was with twin electrics fitting too.
For buying the towbar and electrics kit itself towequipe are the place to go, I have been using them for about 10 years and the only towbar I had trouble with didn't come from them. Carl.
Posted on Tuesday, December 18, 2012 at 11:02 AM
McSwede
Don't do it!!! All of a sudden you'll be dragging your house behind you, badly tarmacking peoples driveways and having an unreasonable amount of Dags in your moveable home.
Posted on Tuesday, December 18, 2012 at 6:28 PM
dudeluk
McSwede said... Don't do it!!! All of a sudden you'll be dragging your house behind you, badly tarmacking peoples driveways and having an unreasonable amount of Dags in your moveable home.
Yeah, that's not going to happen EVAR!!!! That house dragging should be banned if you ask me anyway! Thanks for your help John and Dr C!
Posted on Tuesday, December 18, 2012 at 6:34 PM
Dr Carlos
 It's a means to an end though, you need somewhere to kip when you are away racing the thing in my avatar.
Carl.
Posted on Tuesday, December 18, 2012 at 9:27 PM
Flewy
dudeluk said... I'm looking to fit a hitch to the old family bus (Touran). Can anyone recommend a place in the UK that fits them for reasonable money. Or should I attempt to do it myself...?!
Thanks!
Pretty straightforward to fit, although some need the underside of the rear bumper trimming neatly to suit. Some also require the removal of the bumper to actually fit the framework. I've found that most vehicles from 2000 onwards have any mounting holes pre punched for easy identification although some are hidden beneath the sound deadning. Best bet is to use a manufacturers fitting kit for the wiring as it will come with everything prewires and any bypass relays required too. Scotch locks don't work well with Can-Bus wiring either, avoid using them. Last thing I can add is that your Touran may need hooking up to diagnostics to program the ECU to recognise the extended length of the trailer wiring coupled to the car.
Posted on Wednesday, December 19, 2012 at 9:30 AM
Flewy said... Scotch locks don't work well
Racist. Its not Mik's fault he's from north of the border.
Posted on Wednesday, December 19, 2012 at 9:35 AM
Posted on Wednesday, December 19, 2012 at 11:13 AM
dudeluk
Flewy said... dudeluk said... I'm looking to fit a hitch to the old family bus (Touran). Can anyone recommend a place in the UK that fits them for reasonable money. Or should I attempt to do it myself...?!
Thanks!
good advice. Most appreciated. So how much do you charge to do it for me..?
Posted on Wednesday, December 19, 2012 at 9:43 PM
Flewy
dudeluk said... Flewy said... dudeluk said... I'm looking to fit a hitch to the old family bus (Touran). Can anyone recommend a place in the UK that fits them for reasonable money. Or should I attempt to do it myself...?!
Thanks!
PM me the vehicle reg and your email address I can provide a proper quote. I'm assuming you like a price for the tow bar and complete kit fitted? Also I'm near Bristol, so you may find it better value to use a local centre. Only too happy to help either way!
