Forums > General > Thermal efficiency in cars
THERMAL EFFICIENCY IN CARS
Just been out the mrs Clio and while we sat in the car with the engine off waiting for our take away :) the car got cold very quickly which is normal, but what if cars were more thermal efficient?
I know weight would be increased which is bad but it would benefit in the summer as once cold the air con wouldn't have to work so hard, right?
Am I talking rubbish here or do I have a point? We have K glass etc and light weight insulation, so could it be done? Or do car makers already take this into consideration.
Updated December 11, 2012 at 10:11 PM
HVAC is complicated. You have to design for the people who constantly fill the car with wet stuff (would destroy insulation) and those who constantly drive with air con on (can destroy electrical connectors by cooling them down and the moisture condensing on them when the car is stopped and of course, weight.
OC I work in the building industry and you can get insulation that is moisture resistant. Yes weight is a problem but surely it could be done.
of course it can be done, i bet a rolls royce is a lot better than a clio.
double glazing would help massively, just like it does in a house, but would also add a lot of weight, and probably at least quadruple the cost of a normal window.
again, i'm sure there are coatings that can be applied to glass, but will people be prepared to pay for it? everything on a car is costed to fractions of a penny.
as for insulation, where is it going to go? modern cars are already fairly well sealed, the door cavity is already packed with impact beams, lock mechanisms, speakers, window motors, sound deadening, and needs to leave room for the window to open, and let water drain out the bottom.
even a basic headlining and doorcard already gives a big insulating effect. i drove my completely stripped out metro in sub zero temperatures and it really wasnt much fun. even the thin board doorcards and thin fabric headlining made a huge difference to interior comfort, for very little weight or cost.
then there is the problem of ventilation. people make a lot of moisture, wet shoes and clothes bring a lot of moisture in, and a car cabin is a pretty confined space so you need good ventilation to stop stale air, which isnt just blowing fresh air in, but letting old air out without creating drafts.
Ron Burgundy said...
Does the same material work in -30C to 50C conditions, in direct contact with a wet item for months on end without smelling/rotting/loosing effectiveness, weigh very little and cost next to nothing? How does it perform in a fire and with chemicals such as petrol, oil, sun tan lotion, make up etc?
I'm afraid the answer is yes to your examples. The only one I can't answer is petrol/oil, but then if you have petrol/oil in areas where they shouldnt be ie behind door cards etc then Id say the car has a problem. As mentioned in this thread you need a certain amount of air flow around insulation. If you didn't materials sweat naturally in the changing atmosphere.
The reason they don't do it is because there isn't a need to. The engine produces several times more waste heat than that required to heat the cabin. Insulating a car so it can be sat in whilst waiting for your takeaway is probably not one of the test cases they use.
Motorcycle Tyres | Motorcycle Covers | Motorcycle Luggage | Motorcycle Accessories | Motorcycle Parts - Opening Soon!
The fact the car produces enough heat to waste is a good enough answer to me, but its ok for the air con to pump away hard and fast in the summer? I was using the takeaway situation as an example to say how quick the heat was lost.
If it was that big an issue, cars painted black and other dark shades would not be produced.
New houses still get damp on the inside if they're left in the winter for several weeks, without the central heating on.
So a couple of questions for you:
What does the typical AC unit cost the manufacturer?
How much does a modern AC unit affect fuel consumption?
How often is an AC unit actually in use (remember even when the AC is on, the compressor cycles in and out)?
How much would it cost the manufacturer to insulate cars to a higher standard?
What effect on economy would carting around all that additional weight all the time have?
I don't know REV this is what I wanted to know. Is it worth it? I don't know the costs of items etc this is why I stated at the start am I talking rubbish.
My mates E91 330 has a "REST" button. Which apparently allows the heater to work when the engine is off.
"The encounter was a victory, but we
show it as an example of what not to do."
scotta said...
I've had that in my BMWs...may even have it in the E38 can't remember. But it only works for a short period I think...
BMW Car Magazine
ShockDiamonds said...
scotta said...
The E39 had something like this but I can't remember exactly what. Jobbo will confirm.
Romantic BDSM
Would you raise a hand to Evana? She'd kick your ass. Then insert stiletto heels up it.
In that case, yes. Yes, you are. There's just no advantage to doing it. When the car is being driven it produces enough heat (or power to drive the AC) and that covers 99% of the heating/cooling requirements.
If you want heat or cooling not run off the engine, then auxiliary heating and cooling devices are available (campers, trucks, Dave90210!'s Land Rover etc.)
IIRC you need an auxiliary heater to pre-warm the car, as it's illegal to leave an unattended vehicle idling.
Except ambulances, obv.
My mats are blank. My eyes are dry.
Jimmy Choo said...
scotta said...
It circulates the warm coolant through the heater matrix to allow you to use the residual heat to keep the car warm when the engine is off.
Si_ said...
What about cars with remote start?
JustMax said...
Si_ said...
Yes.
You MUST NOT leave a parked vehicle unattended with the engine running #HighwayCode rule 123
