Posted on Friday, December 7, 2012 at 12:50 PM
Grezza
I've just had two new tyres fitted to the rear of the MCS. Unfortunately one DOT marking says "4012" and the other "4612". Should I just scrap the car?
Posted on Friday, December 7, 2012 at 12:56 PM
Alex_
Burn it!
Updated December 7, 2012 at 12:57 PM
Posted on Friday, December 7, 2012 at 1:09 PM
They were manufactured 6 weeks apart. Burn the car and your house to the ground immediately.
Posted on Friday, December 7, 2012 at 1:10 PM
Bryn_P
Grezza said... I've just had two new tyres fitted to the rear of the MCS. Unfortunately one DOT marking says "4012" and the other "4612". Should I just scrap the car?
I would. Think yourself lucky you don't live in Switzerland, it's probably a crime there  Cheers,
Bryn.
Performance Legends
Posted on Friday, December 7, 2012 at 1:31 PM
My mats are blank. My eyes are dry.
Posted on Friday, December 7, 2012 at 1:52 PM
NotoriousREV
mik said... They were manufactured 6 weeks apart. Burn the car and your house to the ground immediately.
The rules clearly state: - If your tyres are manufactured during different manufacturing weeks, you must immediately burn your car and your house to the ground immediately
- In the manufacturing dates are more than 4 weeks apart, you must also kill you wife and children in a ritual suicide that ends in a police shootout
Motorcycle Tyres | Motorcycle Covers | Motorcycle Luggage | Motorcycle Accessories | Motorcycle Parts - Opening Soon!
Posted on Friday, December 7, 2012 at 1:56 PM
I've just double-checked the 2012 amendment to the act, and it appears Rev is correct.
Posted on Friday, December 7, 2012 at 2:48 PM
Until last year, my car had the original (grey, cracked) identically dated OEM tyres on it. Confusingly, they were dated a couple of months younger than the car - do they swap them when they come off the boat? I've just had to re-replace the rears, and now the dates don't match.
Posted on Friday, December 7, 2012 at 3:13 PM
Grezza
Thanks for the help chaps. Should I also murder everyone that has ever used this forum?
Posted on Friday, December 7, 2012 at 3:18 PM
Mark BT52
What if you put a directional tyre on the wrong way round (and it isn't a Caterham on Avons)?
Updated December 7, 2012 at 3:19 PM
Posted on Friday, December 7, 2012 at 3:24 PM
zedleg
Mark BT52 said... What if you put a directional tyre on the wrong way round (and it isn't a Caterham on Avons)?
Posted on Friday, December 7, 2012 at 3:49 PM
If you fit a directional tyre backwards, it actively sucks moisture out of the air, and your car floats around on a little bubble of water.
Posted on Friday, December 7, 2012 at 3:51 PM
Grezza
OK. Now your mighty brains have processed the idea of different DOT codes, I'm compelled to admit that the old tyres on the front are runflats but the new ones on the back aren't...
Mark BT52
How about a directional asymmetric tyre on the wrong way round AND the inside on the outside? AND the one on the other side has a slightly different tread depth (rolling radius? )
Updated December 7, 2012 at 3:52 PM
Posted on Friday, December 7, 2012 at 3:56 PM
Your car would tear in half. Fitting runflats on the front and non-runflats on the back will probably give comedy handling
Posted on Friday, December 7, 2012 at 4:12 PM
Grezza
Yeah I suppose, I was just sick of the rock hard ride but am too tight to chuck away tyres with decent tread on the front. Besides, I'd managed to start wearing down the tread wear indicators on the rear so I suspect the front/rear balance may have been slightly different to the factory set up.
Posted on Friday, December 7, 2012 at 4:19 PM
Posted on Friday, December 7, 2012 at 4:25 PM
When I had a mini my local tyre place refused to mix runflats with squidgy tyres.
Posted on Friday, December 7, 2012 at 4:32 PM
Tim
Si_ said... When I had a mini my local tyre place refused to mix runflats with squidgy tyres.
When I had the rideruiners on my 5'er replaced the tyre place wrote a schpeel at the bottom of the invoice that they wanted me to sign before they'd do it. I drew a along with my sig.
Tim Balance Bikes from STRIDER & Kiddimoto, HARO BMX Bikes to suit from age 4
