Posted on Wednesday, December 5, 2012 at 3:29 PM
Holley
from 200kph to 300kph in 5.54 seconds
Posted on Wednesday, December 5, 2012 at 3:41 PM
pilouil
that it continues to accelerate like this at high speeds is bloody impressive
definitely not bad for a "tuned exige"
Posted on Wednesday, December 5, 2012 at 3:44 PM
I do like them. LS7 sounds fantastic and that is alotaponies
Posted on Wednesday, December 5, 2012 at 4:02 PM
A bespoke aluminum tub ? looks stretched to me.
Updated December 5, 2012 at 4:02 PM
Posted on Wednesday, December 5, 2012 at 4:26 PM
_Mick_N said... A bespoke aluminum tub ? looks stretched to me.
Chassis unchanged I would think, bespoke subframe to stretch the rear end though.
Posted on Wednesday, December 5, 2012 at 4:33 PM
According to this Click The Venom's entire body is handmade out of carbon fiber, save the original doors. Hennessey redesigned the entire front and rear subframes from scratch to support the longer wheelbase and weight of the engine
Updated December 5, 2012 at 4:34 PM
Posted on Wednesday, December 5, 2012 at 4:42 PM
pilouil
The Venom GT website says: "Note: The Hennessey Venom GT design is based on the Lotus Elise / Exige. The Venom GT is created from a base Lotus Elise / Exige and utilizes components including but not limited to the roof, doors, side glass, windscreen, dash, cockpit, floorpan, HVAC system, wiper and head lamps. Hennessey Performance and the Venom GT are not associated with Lotus Cars."
Posted on Wednesday, December 5, 2012 at 4:49 PM
pilouil said... The Venom GT is created from a base Lotus Elise / Exige and utilizes components including windscreen
Thank. Fcuk
Posted on Wednesday, December 5, 2012 at 5:07 PM
Impressive figures, but the car doesn't do it for me...
Posted on Wednesday, December 5, 2012 at 5:14 PM
What was with the diesel* like cloud of smoke in the drive by shot? * slightly embellished.
Posted on Wednesday, December 5, 2012 at 5:22 PM
DeskJockey said... What was with the diesel* like cloud of smoke in the drive by shot? * slightly embellished.
Over fuelling to save the motor I would guess. Results in bore wash as unburnt fuel washes oil through etc.
Posted on Wednesday, December 5, 2012 at 5:25 PM
Ovefueled probably.
Posted on Wednesday, December 5, 2012 at 5:40 PM
Mike RT4
I'd say it was the aero lifting the dust off the runway, as it didn't appear to be that bad from the reverse camera shot. My car does this at high speed... If the road is wet, it creates an extremely impressive vortex that you don't want to be behind as you can't see anything with the amount of water it lifts off the road .
Posted on Wednesday, December 5, 2012 at 5:41 PM
I'll respectfully disagree Mike, you can just about make out a gap in the smoke when he changes up, and its too dark to be dust shirley?
Posted on Wednesday, December 5, 2012 at 6:05 PM
Mike RT4
Barry said... I'll respectfully disagree Mike, you can just about make out a gap in the smoke when he changes up, and its too dark to be dust shirley?
I'm okay with that, but how do you explain the rear view compared to the static camera view, as you can see the amount it overfuels from that angle, and that doesn't account for the amount of dust in the static view ? Having seen LOADS of these kind of runs on airfields, this is the norm with any car that has even the remotest amount of aero. Shame there was no side view, as the rooster tail is spectacular . Next time it is wet and I'm out in the Cossie, I'll twist the camera around for a rear view, so you can see how much it lifts stuff off the road surface as the water gives a visual guide of what it is doing (and my aero is NOTHING as impressive as these kind of cars) .
Posted on Wednesday, December 5, 2012 at 6:18 PM
I would suggest the visual gap with the rear cam is simply the smoke/fumes not immediately reacting with the air on the outside world, creating a gap immediately behind the vehicle (along with aero effects pulling it all away violently of course) ? Not that it matters either way, its still an impressive sight to behold
