Posted on Tuesday, December 4, 2012 at 10:52 AM
I know you are all forgetful, so thought I'd remind you all (after seeing my neighbour struggle to get into their car at the weekend). Wipe door seals with clear silicone shoe-shine. Takes seconds and works a treat. Many brands available. Here endeth this tip reminder.
Posted on Tuesday, December 4, 2012 at 11:10 AM
Or buy a garage.
Posted on Tuesday, December 4, 2012 at 11:13 AM
Marv makes a good point.  If your car is currently parked outside, then either do this, or buy a garage. Ensure all of your journeys have a garage at the other end too guys. Phone Claridges if you need any help.
Posted on Tuesday, December 4, 2012 at 11:19 AM
SimonB
Oh and DO remember to drive to the conditions.  As for the shoe shine tip - buy a better car if that happens.
Posted on Tuesday, December 4, 2012 at 11:20 AM
I'm not sure if Mik's suggestion is any cheaper, but personally I recommend the proper stuff: Gummi Pflege.
Posted on Tuesday, December 4, 2012 at 11:22 AM
Which reminded me I need to get some new door seals for the Volvo. Two of them are looking rather worse for wear.
Posted on Tuesday, December 4, 2012 at 11:23 AM
Just buy a garage Deskjockey. Problem solved.
Posted on Tuesday, December 4, 2012 at 11:34 AM
Thanks for the reminder guys.
Posted on Tuesday, December 4, 2012 at 11:38 AM
My garage is full of cr*p however I've a carport too and that's great, no frost or ice problems on the car and no opening and closing of garage doors. The builders turn up next year and it's going to be filled in, I'll certainly miss it though, very handy.
Posted on Tuesday, December 4, 2012 at 11:43 AM
I have a can of silicone spray - do you think that would work well enough?
Posted on Tuesday, December 4, 2012 at 11:45 AM
_Mick_N said... My garage is full of cr*p however I've a carport too and that's great, no frost or ice problems on the car and no opening and closing of garage doors. The builders turn up next year and it's going to be filled in, I'll certainly miss it though, very handy.
Why does a carport make any difference? I used to park in one and experienced the same thing - no frost even on the coldest of days. It certainly doesn't notably affect the temperature, so I guess it's that moisture comes mainly downwards out of the sky, and a car port etc shelters the car from it?
Posted on Tuesday, December 4, 2012 at 11:49 AM
What about Vaseline? I've read before on the internet that it's a very bad thing to put on rubber as it degrades it, but I used to use it on all the seals on the old mk1 Clio seemingly without ill-effect.
Posted on Tuesday, December 4, 2012 at 11:52 AM
Well the roof / walls must radiate some heat and also as you so no where for water droplets to settle. Even when it got to minus 15 or so there still wasn't any ice problems.
Posted on Tuesday, December 4, 2012 at 11:59 AM
Swervin_Mervin said... What about Vaseline? I've read before on the internet that it's a very bad thing to put on rubber as it degrades it, but I used to use it on all the seals on the old mk1 Clio seemingly without ill-effect.
No wonder you couldn't sell it!
Posted on Tuesday, December 4, 2012 at 12:14 PM
The Saab is one of the worst cars for freezing door seals. YOu would think being Swedish it would be quite handy in cold temperatures. As I have no room or cash for a garage I may get some shoe polish. Cheers.
Posted on Tuesday, December 4, 2012 at 1:57 PM
caneswell
_Mick_N said... Well the roof / walls must radiate some heat and also as you so no where for water droplets to settle. Even when it got to minus 15 or so there still wasn't any ice problems.
Also reflects the heat the car would normally be radiating out into space on a clear night.
Posted on Tuesday, December 4, 2012 at 4:16 PM
ilmostro
mik said... Marv makes a good point.  If your car is currently parked outside, then either do this, or buy a garage. Ensure all of your journeys have a garage at the other end too guys. Phone Claridges if you need any help.
Just get one of your servants to kip in the car overnight, and fire it up 1/2 hour before you need it.
Posted on Tuesday, December 4, 2012 at 4:24 PM
mik said... Just buy a garage Deskjockey. Problem solved.
Have a garage (although no access - landlord is using it to store rubbish in), but even if we could use it the thing is so narrow I wouldn't be able to get out of the car.
Posted on Tuesday, December 4, 2012 at 4:39 PM
DeskJockey said... mik said... Just buy a garage Deskjockey. Problem solved.
Climb out of the rear hatch.
