Posted on Thursday, November 29, 2012 at 11:32 AM
Zonda_
The last 2 days when I've gone to turn it on it refuses to do anything, the led on the back shows there is power but nothing happens, it was rather cold here the past couple of nights and on feeling the case it was cold but not that cold. Unplugging it and standing it by a radiator for 5 minutes had it working fine, same this morning. Obviously this is getting somewhat tiresome! What controls the temperature at which it will turn on? Over the years I've had about 8 pc's that have all lived in exactly the same spot and never had a problem. It's a 6 week old Dell Inspiron btw and no it can't be moved anywhere else.
Posted on Thursday, November 29, 2012 at 11:53 AM
Zonda_
As I said, it's cold but not that cold, hasn't even hit minus figures yet!
Posted on Thursday, November 29, 2012 at 11:57 AM
Mark BT52
You have a female computer.
Posted on Thursday, November 29, 2012 at 11:58 AM
Your computer is faulty, raise a support ticket.
Posted on Thursday, November 29, 2012 at 12:00 PM
exiges
Zonda_ said... Unplugging it and standing it by a radiator... and no it can't be moved anywhere else.
Ampera • Women • Car Trade
Posted on Thursday, November 29, 2012 at 12:03 PM
Zonda_
exiges said... Zonda_ said... Unplugging it and standing it by a radiator... and no it can't be moved anywhere else.
The radiator is by the door in an inspired move by the house 'designers'. There is nowhere else in the room it could go and frankly when every other machine has performed fine there why should it?
Posted on Thursday, November 29, 2012 at 12:04 PM
Si_ said... Your computer is faulty, raise a support ticket.
Posted on Thursday, November 29, 2012 at 12:07 PM
Zonda_
I'm busy trawling the Dell site to find out how to do it!
MattyB_
It's usually the colder the better with PC's (within reason). Sounds like a bad connection somewhere. Heat causes metal to expand, etc.
ClubLupo
Technomotive - Games, Cars, Stuff
Posted on Thursday, November 29, 2012 at 12:13 PM
There are proably jumpers on your motherboard. Pull these out and put them on the computer to keep it warm. Job jobbed.
Posted on Thursday, November 29, 2012 at 12:19 PM
Gino Pilotino
likely it's the elder coin battery on the motherboard (used to keep bios setting saved) going nuts: go and replace it with something in a better shape, less than 1 pound should do the trick.
Posted on Thursday, November 29, 2012 at 12:21 PM
Zonda_
Gino Pilotino said... likely it's the elder coin battery on the motherboard (used to keep bios setting saved) going nuts: go and replace it with something in a better shape, less than 1 pound should do the trick.
The machine is 6 weeks old!
Posted on Thursday, November 29, 2012 at 12:41 PM
Pay your Mum some board and she might put some money in the meter.
Posted on Thursday, November 29, 2012 at 2:11 PM
Mark BT52 said... You have a female computer.
Posted on Thursday, November 29, 2012 at 2:49 PM
Ali.
My work PC has exactly the same problem. I cured it (sort of) by placing one of those electric oil radiators with a timer next to it (on a low heat) before i leave the office, setting it to switch on an hour before i get there in the morning.
Never say no to a panda.
Posted on Thursday, November 29, 2012 at 3:25 PM
Most electrical stuff will have an operating temperature range in the manual. read that and if the temperature is within that range but not working send it back.
Posted on Thursday, November 29, 2012 at 3:26 PM
simongardner
I'd bet on dry joints somewhere - probably motherboard or power supply. Can work your way round them with a soldering iron if you know what you're doing, or possibly the oven trick (190-200 degrees for a few minutes) as a last resort if you were going to bin it anyway.
