Posted on Wednesday, November 28, 2012 at 9:59 PM
NotoriousREV
Are there any good, preferably free apps on Mac that can clean up my music collection after iTunes has borked it then re-import it into iTunes? I've ended up with several thousand duplicates thanks to the way iTunes has tried to organise my folders after copying them from other PCs. e.g. BumCop by Crazy Penis is in a "Crazy Penis" folder, a "Ministry of Sound Presents Chilled Sessions" folder a "Ministry of Sounds Presents Chilled Sess" folder and another folder that seems identical to another folder but somehow isn't. F*cking iTunes! Although, just to be clear, I want to pull my stuff out of iTunes, clean it up then stick it back in (requote at will). I don't want to move away from using iTunes normally.
Posted on Wednesday, November 28, 2012 at 10:54 PM
David_Yu
No idea. But under the same title, how can I update an app via iTunes on the laptop rather than directly on the iPhone?
TomTom just released an update, but says if I do it on the phone I will lose all settings, and to do it via "the iTunes app on my computer".
www.auto-journals.com Real life with cars
Posted on Wednesday, November 28, 2012 at 11:49 PM
ilmostro
Apps/Updates Available, then Sync?
Posted on Thursday, November 29, 2012 at 9:05 AM
hoyleyboyley
tune up? its an add on - finds missing artwork and sorts duplicates for you.
Hmmmmm BO! BO! Chick.............. Chick a chickaaahhh!
Posted on Thursday, November 29, 2012 at 9:38 AM
David_Yu
ilmostro said... Apps/Updates Available, then Sync?
Can't find an update button anywhere on iTunes. You can "buy" it, but I don't want to risk buying it again when all I want to do is update it. Annoyingly, my phone is saying it doesn't have enough space to download the update directly anyway, despite showing having plenty of spare space!
Posted on Thursday, November 29, 2012 at 9:45 AM
David, have you ever synced the phone with iTunes? Do that and make sure it is set to copy across apps purchased on the phone (I thought that was the default but it could be turned off). Then it'll show in iTunes as an app, and it'll allow you to update.
Posted on Thursday, November 29, 2012 at 9:56 AM
David_Yu
Jobbo said... David, have you ever synced the phone with iTunes? Do that and make sure it is set to copy across apps purchased on the phone (I thought that was the default but it could be turned off). Then it'll show in iTunes as an app, and it'll allow you to update.
Yeah I sync it occasionally and did so yesterday to try exactly what you (and Apple) suggested, but on the iTunes App manager, I can see TomTom, but nowhere does it tell you that it has an updated version available or how to update it, only to "purchase" it at £54.99! On the phone, that is sort of how you update it, i.e. by pressing "install" and it updates it, but I don't want to risk paying another £55 for something I already paid for!
Updated November 29, 2012 at 9:58 AM
Posted on Thursday, November 29, 2012 at 10:16 AM
All your other apps are in the iTunes app manager? Weird; maybe try downloading a new free one on your phone, syncing, and see if it appears in iTunes. I have found that stuff doesn't copy across to iTunes when I sync sometimes unless I manually sync again after the auto-sync when I first connect.
Posted on Thursday, November 29, 2012 at 10:21 AM
NotoriousREV
hoyleyboyley said... tune up? its an add on - finds missing artwork and sorts duplicates for you.
Yeah, I saw that but they want $50 (or $40 for a 1 year licence) for it and I'll probably only ever use it once plus I wasn't sure if it was any good or not i.e. I was hoping to find someone with real world experience of something.
Posted on Thursday, November 29, 2012 at 10:25 AM
David_Yu
Jobbo said... All your other apps are in the iTunes app manager? Weird; maybe try downloading a new free one on your phone, syncing, and see if it appears in iTunes. I have found that stuff doesn't copy across to iTunes when I sync sometimes unless I manually sync again after the auto-sync when I first connect.
The app was there, I just couldn't see an update button, but I've just noticed a "search for updates" button at the bottom of the app listing page, so done! Will sync it up once it's downloaded.
Posted on Thursday, November 29, 2012 at 7:35 PM
NotoriousREV said... Are there any good, preferably free apps on Mac that can clean up my music collection after iTunes has borked it then re-import it into iTunes? I've ended up with several thousand duplicates thanks to the way iTunes has tried to organise my folders after copying them from other PCs. e.g. BumCop by Crazy Penis is in a "Crazy Penis" folder, a "Ministry of Sound Presents Chilled Sessions" folder a "Ministry of Sounds Presents Chilled Sess" folder and another folder that seems identical to another folder but somehow isn't. F*cking iTunes! Although, just to be clear, I want to pull my stuff out of iTunes, clean it up then stick it back in (requote at will). I don't want to move away from using iTunes normally.
I havent found a way to clean it up - but I have found by selecting the "duplicates that are not " together and right clicking --> get info --> then make them part of the same collection works ..
Posted on Thursday, November 29, 2012 at 7:38 PM
Incidentally itunes 11 has just dropped ..
Posted on Thursday, November 29, 2012 at 8:38 PM
NotoriousREV
andybond said... NotoriousREV said... Are there any good, preferably free apps on Mac that can clean up my music collection after iTunes has borked it then re-import it into iTunes? I've ended up with several thousand duplicates thanks to the way iTunes has tried to organise my folders after copying them from other PCs. e.g. BumCop by Crazy Penis is in a "Crazy Penis" folder, a "Ministry of Sound Presents Chilled Sessions" folder a "Ministry of Sounds Presents Chilled Sess" folder and another folder that seems identical to another folder but somehow isn't. F*cking iTunes! Although, just to be clear, I want to pull my stuff out of iTunes, clean it up then stick it back in (requote at will). I don't want to move away from using iTunes normally.
A quick way is to copy all your music to another folder, delete the library then copy your music back. Problem is I do have a couple of thousand actual duplicates. I think I'll have to buy Tuneup.
Posted on Thursday, November 29, 2012 at 8:42 PM
PugRallye2
My brother-in-law asked me to do a similar thing a few months back. He'd been using iTunes for a couple of years and everything was a complete mess - dupes, odd tracks here and there, missing/wrong/incomplete tags, missing/wrong album art etc. I spent a bit of time on it, then just gave up. There's no easy way around this apart from taking the time to make sure all the tags, art, folder/file names etc are correct up-front (when you rip/download/import). Sorry...
Posted on Thursday, November 29, 2012 at 9:19 PM
ilmostro
David_Yu said... ilmostro said... Apps/Updates Available, then Sync?
DELETE ALL SAT NAV APPS - else your ass will be raped by this forum!
Posted on Thursday, November 29, 2012 at 10:06 PM
Try copytrans. Just dont install iTunes11 before - its too new ..
Posted on Friday, November 30, 2012 at 10:34 AM
I used Itunes Library Updater this before I realised iToonz is shyte and went with WinAmp. Product is old and hasn't been updated for a long time, but it worked with the last version of iTunes I used (8-something?). Freeware so nothing lost by trying.
Posted on Friday, November 30, 2012 at 2:26 PM
nomoregti
andybond said... Incidentally itunes 11 has just dropped ..
Just updated this without really looking at the fact it was a whole new generation...
Me no likey change.
Posted on Sunday, December 2, 2012 at 9:40 PM
markmctavish
Tune Up is pretty popular. There are a couple of cheaper alternatives as well if you do a Google.
