Posted on Monday, November 26, 2012 at 8:14 PM
David_Yu
It was on at 7pm (or just started on Nat Geo+1 ) and will be repeated at 8am on Wednesday and 11am on Thursday. Great updated programme following the excellent one they did after the car was launched.
Some odd sections where they appear to have dubbed a Ferrari's soundtrack over the VR38 though...  It confirmed what I was told though, that every GT-R is scrupulously thrashed by a test driver up 7k rpm and up to 100mph on a test circuit after assembly. So why bother with all the namby pamby running in procedure that Nissan print in their handbook?
www.auto-journals.com Real life with cars
Posted on Monday, November 26, 2012 at 8:50 PM
Watched it, entertaining program, however I was lolz'ing at teh downforce
Posted on Monday, November 26, 2012 at 9:15 PM
N
David_Yu said... It confirmed what I was told though, that every GT-R is scrupulously thrashed by a test driver up 7k rpm and up to 100mph on a test circuit after assembly. So why bother with all the namby pamby running in procedure that Nissan print in their handbook
Exactly what I said to my father.
Posted on Monday, November 26, 2012 at 9:50 PM
David_Yu
N said... David_Yu said... It confirmed what I was told though, that every GT-R is scrupulously thrashed by a test driver up 7k rpm and up to 100mph on a test circuit after assembly. So why bother with all the namby pamby running in procedure that Nissan print in their handbook
Has he bought one? Porsche and Ferraris are bench run and test driven too, so again, why bother with running-in? Especially as most Ferraris don't exceed the running-in mileage in their first year...
Posted on Monday, November 26, 2012 at 9:55 PM
N
David_Yu said... Has he bought one?
I wish
Posted on Monday, November 26, 2012 at 10:48 PM
pilouil
David_Yu said... Porsche and Ferraris are bench run and test driven too, so again, why bother with running-in? Especially as most Ferraris don't exceed the running-in mileage in their first year...
The F430 and 599 GTB user manuals only ask for a "1000 km (620 mi.)" run-in, limiting rev to 5000 rpm (I suppose it should be the same for other recent Ferraris).
Posted on Monday, November 26, 2012 at 10:50 PM
pilouil
And since when could a complicated Fiesta be considered as a supercar? (just joking)
Posted on Monday, November 26, 2012 at 10:55 PM
David_Yu
pilouil said... David_Yu said... Porsche and Ferraris are bench run and test driven too, so again, why bother with running-in? Especially as most Ferraris don't exceed the running-in mileage in their first year...
Exactly, which I never bothered doing with my F430. The test drivers thrash the nuts off them on the roads around Maranello, so keeping it below 5k for 1000kms is a complete waste of time.
Posted on Monday, November 26, 2012 at 11:02 PM
pilouil
I was thinking you assumed a longer run-in - most Ferrari exceed 1000 km in their first year I guess. Anyway I can't buy new, so I don't have to ask myself
Posted on Monday, November 26, 2012 at 11:14 PM
Even regular cars which are not exotic have their engine put on a dyno and revved like nuts to check they work properly. I do remember on a discovery show or something where they said the break in period is mainly to stop people cruising at a constant high speed on the motorway such as at 100 mph as that is what is bad for a new engine whereas revving it is fine. Just high rpm for a constant speed = bad, so tell people to drive slowly to avoid that problem.
Posted on Tuesday, November 27, 2012 at 6:38 AM
Normal cars the engine is built, the engine is stuffed up, fluids added and then at the end of the line a rolling road test is done, thrashing the car through the gears.
Posted on Tuesday, November 27, 2012 at 8:30 AM
Thrashing a car for a couple of minutes and thrashing them for the first thousand miles are massively hugely enormously different. Dave!
Posted on Tuesday, November 27, 2012 at 12:11 PM
Mike RT4
GraniteV8 said... Thrashing a car for a couple of minutes and thrashing them for the first thousand miles are massively hugely enormously different. Dave!
This. This is my engine on the dyno at 8500 rpm.
It has come straight off the build bench, been loaded onto the dyno and then run for a 3 hour load cycle (where the dyno runs the engine at various rpm and load cycles to bed it in). After this, it is then run at full load at each 500 rpm point for 5-10s to complete the full load mapping. Once this has been done and despite the above, it still needs to have the bedding in process finished on the road for a further 6-700 miles....
Updated November 27, 2012 at 12:11 PM
Posted on Tuesday, November 27, 2012 at 12:17 PM
There is something about red hot car bits that makes me go all funny at the knees...
Anyone got that pic of the Zonda tail pipes burning bright purple after Andy Wallace maxed it? That used to give me a right se....never mind.
Posted on Tuesday, November 27, 2012 at 1:18 PM
David_Yu
It always makes me wonder how close they are to melting and just dripping off...  So what wear does the first thousand miles of road use do that the revving the nuts off on dyno and test track doesn't?
And how come no manufacturers recommend oil changes after running in if that much wearing in has taken place? (I always change it after the first 1000-1500 miles anyway as it's cheap to do and makes me feel better.)
Posted on Tuesday, November 27, 2012 at 1:29 PM
Mike RT4
David_Yu said... It always makes me wonder how close they are to melting and just dripping off...  So what wear does the first thousand miles of road use do that the revving the nuts off on dyno and test track doesn't?
On the road, you tend to be driving at particular load points for prolonged periods, on the above picture, you're only at any particular load site for a few seconds at a time, so it doesn't cause any damage. However, because the engine is still very "tight", if you did load it heavily for a prolonged period, it can result in a heat build up, from the friction and subsequent material expansion and cause it to "nip" up or wear more aggressively that particular area. Bedding it in properly means that the contact points have a chance to "wear" together to the correct tolerances . Regarding the running in process, LOTS do (in fact BMW won't warranty an M engine if it doesn't have the required 1200 mile oil and filter change (as I believe they use a low grade bedding in oil, which you obviously don't want to use for prolonged periods).
Updated November 27, 2012 at 1:33 PM
Posted on Tuesday, November 27, 2012 at 1:32 PM
N
David_Yu said... And how come no manufacturers recommend oil changes after running in if that much wearing in has taken place? (I always change it after the first 1000-1500 miles anyway as it's cheap to do and makes me feel better.)
BMW M division it must be important if BMW invalidate your warranty if you miss the 1200 mile running service.
Posted on Tuesday, November 27, 2012 at 2:06 PM
The BMW M Division will inval...
Posted on Tuesday, November 27, 2012 at 2:26 PM
Mike Rainbird said... GraniteV8 said... Thrashing a car for a couple of minutes and thrashing them for the first thousand miles are massively hugely enormously different. Dave!
We used to do exactly that on our test benches, prove that the engine actually does what it was designed to do and then do a set load and speed at set times for the next day to actually run the engine in. We do the same on ships, get it to full load in 4 hours, check everything is running right and then reccomend varying loads while the engine is running in for the first 50 hours or so. Dave!
Posted on Tuesday, November 27, 2012 at 3:53 PM
David_Yu
To be honest, I have always varied the revs/gears and loads when running new cars in. It just seems frustrating to never venture beyond, say, 4,500rpm when the engine has already done far more. GT-R was the easiest as if you leave it in Auto it shifts up before 4,500 in each gear anyway.
They also specified running-in the shocks by only using Comfort until 1k miles or so.
