Forums > Any other business > expensive nail
EXPENSIVE NAIL
To cut a long story short, I ran over a nail in my A8 on Saturday. changed wheel (or rather got wheel changed), and went to get puncture repaired today.
Turns out nail is in side wall, so new tyre needed. Not only that, but because 4wd it needs at least both fronts replaced, if not all 4. It is on the 21 inch wheels, and these tyres aren't even available, so need special order.
This nail looks like it will cost me close to £1300 !!
Alan said...
:roll: and :roll: again. Let me guess, people selling/fitting the tyres told you that?
Fiery death will NOT occur the moment you change just one tyre...
(I hope this doesn't lead us onto rolling radii...)
Updated November 12, 2012 at 5:48 PM
Impreza WRX STi Spec-C V-Limited Toshi Arai Edition/ GT-R/ 320d MSport/ Audi S4
Mark BT52 said...
Almost innevitable.
Bit of a p1sser. Does it have a full size spare? (I'm guessing "no")
I'm not sure Audi themselves even recommend replacing multiple tyres in the event of a puncture. Just replace the one, but with the same as the one which came off.
Wow was I impressed
I hope that's correct !, I had the same advice from 3 different fitters, but then there is a recession on..
Alan said...
Fitters you say.. :D
Just replace the one and ignore them.
found this link, which doesn't really help !
Been running an A8 for 55,000 miles and the front near side has always worn first (obviously), I've only ever changed the pair.
Updated November 12, 2012 at 6:31 PM
Alan said...
not checked the R8s manual but 4wd systems are light years ahead of where they where, my RS4 didn't care about different rolling radius front to rear, nor did my scoobys
i wouldn't be that bothered by a 2mm rolling radius difference side to side either for the diff, having one side aqua planning because of of the tread difference would worry me more
Updated November 12, 2012 at 7:06 PM
Existence is pain ...
You get no sympathy from me for having 21" wheels ;)
as quoted from ELSA (w/s manual) I've 'guessed' a 2007/8 model A8...
General information on wheels and tyres
"The factory recommends using tyres of the same make, design and tread pattern on all wheels.
Always renew the rubber valve when fitting a new wheel rim or tyre.
Tyres are to be fitted with DOT mark facing outer side of wheel. For tyres with directional tread pattern, this only applies to left side of vehicle.
If the vehicle is fitted with tyres with a directional tread pattern, the spare wheel should have a wheel/tyre combination for the right-hand side of the vehicle."
Not a bean on replacing tyres in pairs.
Updated November 12, 2012 at 8:07 PM
Mark BT52 said...
Alan said...
You need new brakes and shocks too.
Carl.
What about the windscreen?
DeskJockey said...
Only if he doesn't mind the future resale value being affected.
Bro... be yourself. Just less so.
mik said...
:lol: sorry to snigger Giles, but that's the nicest cvnty phrase I've read for ages. Will recycle.
he needs a new car.
M235i
I would say to just change the tyres on the same axle. Was this an Audi garage?
Nuts on the road
Be less gulible
