Posted on Friday, September 23, 2011 at 9:13 AM
Firstly - Lambo article this month - fantastic. Really enjoyed it, and the photo sequence(s) of the QV oversteering are great.  You've quoted the Fast Lane test figures, but you're not convinced the car is capable of the 10sec 0-100 they managed. Any empirical reason for your doubt, or just basing this on your (undoubtedly pretty well calibrated) 4rse-dyno? (It's been 15yrs since I read the FL test, but I probably read it 30x as a youngling (mostly whilst dribblin'). I remember Dron making a couple of comments about the car (Pierluigi Martini's own) being in fine fettle, and there was definately a comment that the rev-limiter didn't appear to be halting play at the appropriate point).
Posted on Friday, September 23, 2011 at 9:17 AM
And who was responsible for this skidz i've never seen someone do this in a Countach on the road
Posted on Friday, September 23, 2011 at 9:20 AM
Based on the (mag) text I'd say Mr Harris Esq.
Updated September 23, 2011 at 9:20 AM
Posted on Saturday, September 24, 2011 at 4:31 AM
Visceral1111
It seems like Bovingdon used your route in his GT3 RS 4.0 video review (which btw I thought was quite good). On the skid- it sounds like you didn't use many revs, and the angle is just meh.
Posted on Saturday, September 24, 2011 at 7:42 AM
It does look like he was holding off a little, probably because it is Harry's car !
Posted on Saturday, September 24, 2011 at 7:52 AM
Former Member
They'll probably refuse to respond, because you insist on spelling 'definitely' incorrectly
Posted on Saturday, September 24, 2011 at 8:24 AM
ShockDiamonds said... They'll probably refuse to respond, because you insist on spelling 'definitely' incorrectly
I've always done that . I've decided it gives my writing character however....
Posted on Monday, September 26, 2011 at 1:52 AM
Visceral1111
NotoriousREV said... Visceral1111 said... It seems like Bovingdon used your route in his GT3 RS 4.0 video review (which btw I thought was quite good). On the skid- it sounds like you didn't use many revs, and the angle is just meh.
Yeah? Let's see your drift skills then
And would that change the quality of the drift? He's a great driver. I expected more. That's all.
Posted on Monday, September 26, 2011 at 7:45 AM
Visceral1111 said... NotoriousREV said... Visceral1111 said... It seems like Bovingdon used your route in his GT3 RS 4.0 video review (which btw I thought was quite good). On the skid- it sounds like you didn't use many revs, and the angle is just meh.
reading the article in the mag, it sounds like he nearly disclocated his shoulder in the process. Can be forgiven for the quality then !.
Posted on Monday, September 26, 2011 at 8:59 AM
DaveD
It might not have been on the lock stops but that was a PERFECT balance of throttle and steering . My ham-fisted oversteer efforts involve big stabs of throttle and some mashing of the wheel, whereas CH held a pretty constant steering angle and very constant throttle. That takes a lot of skill IMO.
Updated September 26, 2011 at 9:01 AM
Gloucestershire Wedding Photography
Family Portraits Cheltenham
Posted on Monday, September 26, 2011 at 5:31 PM
Visceral1111
those points are all true, but to me it just felt like he was on a diamond ski trail for the first time. The result was that it looked out of character and going back to my initial comment, I would of liked more throttle and a bit more angle--I mean if you're gonna post a video on evo might as well make it nuts worthy.
Posted on Tuesday, September 27, 2011 at 10:01 AM
Mike RT4
DaveD said... Visceral1111 said... It seems like Bovingdon used your route in his GT3 RS 4.0 video review (which btw I thought was quite good). On the skid- it sounds like you didn't use many revs, and the angle is just meh.
And a perfectly executed clutch kick to get it going !
Posted on Tuesday, September 27, 2011 at 11:10 AM
Monkey Harris
Hmmmm Reason for no more angle is, er, there is no more angle! That's the lock-stops in a Countach. More than happy to defer to other, more accomplished wet-weather Countach drifters out there, of which there appears to be one here.
Posted on Tuesday, September 27, 2011 at 11:18 AM
Monkey Harris said... Hmmmm Reason for no more angle is, er, there is no more angle! That's the lock-stops in a Countach. More than happy to defer to other, more accomplished wet-weather Countach drifters out there, of which there appears to be one here.
This will end upside down, in a hedge or both.
Posted on Tuesday, September 27, 2011 at 11:32 AM
Monkey Harris
On a serious note, that shows how much this type of car has changed over the years. Throttle response was softer, grip levels were lower and the non-assisted steering only allows much slower corrections. Honestly, it won't go much more sideways than that, and the throttle was buried! Was so well balanced though. Great car. Will try to be more of a hoon next time....
Posted on Tuesday, September 27, 2011 at 11:41 AM
Monkey Harris said... More than happy to defer to other, more accomplished wet-weather Countach drifters out there, of which there appears to be one here.
I LOL'ed - good work Chris
Posted on Tuesday, September 27, 2011 at 11:42 AM
[quote="carlos"] And who was responsible for this skidz Well at least it's clear who the Disliker is
Posted on Tuesday, September 27, 2011 at 11:46 AM
I take it the Countach has something like 2 turns lock to lock then, or perhaps less?
Posted on Tuesday, September 27, 2011 at 11:57 AM
Nick Trott
I too was mighty disappointed with Monkey's drift in the Editorial Director's personal £100,000+ 450+bhp V12 Lamborghini Countach with no power steering, little steering lock, terrible tyres, no safety systems, heavy throttle pedal, no run off in wet conditions with the light fading on a crucial cover shoot that if it went wrong would result in the messiest situation that this magazine has ever known.
